HV current limiting - help needed.
DaleW
Newbie
Newbie level 1
I have a high voltage DC power supply, (180VDC), I am looking for a circuit that would allow me to control/limit the current from 1-15A, everything i can find is low voltage (less than 25VDC) and I don't know enough to modify them to work within my voltage/current requirements.
Producing a PCB isn't an issue however, a circuit design known to work because I don't have the ability to prototype it is pretty much a requirement.
The power supply is a toroidal transformer with 3 taps, 0 - 100VAC, 114VAC, 128VAC, a full wave bridge and filtering caps 4800uf@300VDC (4x1200uF) which gives me 140VDC, 160VDC and 180VDC after rectification and filtering but capable of delivering in excess of 40A.
Help in the way of a schematic would be greatly appreciated.
140V x 15A = 2100W of heat worst case (output shorted, supplied from lowest voltage tap ... expected to have automatic tap switching according output voltage.)
2100W of heat --> Nothing I would do using linear current limiting.
--> I´d use a switching circuit to reduce dissipated heat .. (maybe down to less than 1% w.r.t. a linear solution)
40A on a 4800uF gives a voltage drop of 8.3V per millisecond. .. or 83V per 50Hz half wave.
I don´t think it´s a stable bus voltage.
Also: check the ripple current specification of your capacitors.
Klaus
A current mode controlled converter that has an "ISET" pin exposed, would give you a place to apply a variable limit-clamp.
This might look like "COMP" or "EAOUT", have to look at details (which seems to not be desired).
Crude illustration of the buck converter. Transistors/mosfets which tolerate 180V are easier to find than IC's which tolerate 180V. By adjusting bias (as well as frequency, duty cycle) you adjust current through the system.
LaTeX Commands Quick-Menu:
