carpenter
Full Member level 6
In schematics I have two Current transformer see pic.
In real and on PCB ic current transformát small toroid with wire windings
Significantly, toroids is one second and primary wire is inserted through them.
On PCM is only two pad.
I make two foot print for T1 ant T2 with shifted pad for secondary winding.
the primary problem is how best to ensure
pat1 T1 = pad2 T2 it is problem
pat2 T1 = pad1 T1 it is OK
I know I can do it manually redefine the PCB editor, but I do not consider systemic solutions
