Hilbertstrauss
Newbie level 5
Greetings,
I tried to simulate the simple following power divider in schematic in ADS 2016,
I got the following s parameters,
Then I made the same circuit in layout and run a momentum microwave simulation,
As you can see, the results were very different from those obtained using schematic,
What might cause the momentum simulation parameters/design to give results that are so different from those obtained with schematic? I used the following settings:
If needed, the workspace folder can be found here: https://drive.google.com/file/d/135CLcoooKmi5xk7iEFp4FcsDqI3TENIO/view?usp=sharing
Thank you!
Thank you!
