huffman encoder/Decoder For Text data compression
kude
Newbie level 3
Newbie level 3
Hi All,
I am working on Huffman Encoder/Decoder for text compression/Decompression.And here are the things not clear for me.
1.How can I give text input (Whole text once) to the FPGA.
2.When I encode the data the output code length is not fixed and how can I manage this with constant I/O pins of the FPGA.
3.When Encoding the text I have to use heaps,Sort and mearge but this things are not synthesizable in FPGA
thanks in advance
hi kude
1)in my opinion, you can send the input data stream using a RAM. put all the data in a RAM and read it per clock.
2)the only way you can 'fixed' the output is using shift register or concatenate the output maybe into 32bits and try to store it somewhere before read it.
3)not really sure..
may its help..
You will need some sequential elements in your design. Are you familiar with state machines?
Are you really sure an FPGA is the correct way to do the job? Do you have certain reauirements to speed of encoding/decoding that is not possible with standard processors/microcontrollers?
Please give me some more background on the requirements, maybe much better solutions exist.
Stefaan
Reactions: zel
    zel
