Hspice warnings: delay greater than piece-wise
yen
Member level 5
Member level 5
Hello,
I am run my circuits in hspice. But it has a warning about my input. So my result is wrong.How do I do? Thanks.
**warning** delay greater than piece-wise in 0:vv0 0.00000D+00
**warning** delay greater than piece-wise in 0:vv1 0.00000D+00
**warning** delay greater than piece-wise in 0:vv2 0.00000D+00
**warning** delay greater than piece-wise in 0:vv3 0.00000D+00
**warning** delay greater than piece-wise in 0:vv4 0.00000D+00
**warning** delay greater than piece-wise in 0:vv5 0.00000D+00
**warning** delay greater than piece-wise in 0:vv6 0.00000D+00
**warning** delay greater than piece-wise in 0:vv7 0.00000D+00
hspice question
can you try to post part of your netlist?
Re: hspice question
Dear kienhuy,
My inputs are like below.
time v11 v10 v9 v8 v7 v6 v5 v4 v3 v2 v1 v0
0 0 0 0 0 0 0 0 0 0 0 0 0
7.3242e-010 1.8 0 0 0 0 0 0 0 0 0 0 0
9.7656e-010 1.8 0 0 0 0 0 0 0 1.8 1.8 0 0
1.709e-009 1.8 0 0 0 0 0 0 0 1.8 1.8 0 0
1.9531e-009 1.8 0 0 0 0 0 0 1.8 1.8 0 0 1.8
2.6855e-009 1.8 0 0 0 0 0 0 1.8 1.8 0 0 1.8
2.9297e-009 1.8 0 0 0 0 0 1.8 0 0 1.8 0 1.8
3.6621e-009 1.8 0 0 0 0 0 1.8 0 0 1.8 0 1.8
3.9062e-009 1.8 0 0 0 0 0 1.8 1.8 0 0 1.8 0
4.6387e-009 1.8 0 0 0 0 0 1.8 1.8 0 0 1.8 0
4.8828e-009 1.8 0 0 0 0 0 1.8 1.8 1.8 1.8 1.8 0
5.6152e-009 1.8 0 0 0 0 0 1.8 1.8 1.8 1.8 1.8 0
5.8594e-009 1.8 0 0 0 0 1.8 0 0 1.8 0 1.8 1.8
6.5918e-009 1.8 0 0 0 0 1.8 0 0 1.8 0 1.8 1.8
6.8359e-009 1.8 0 0 0 0 1.8 0 1.8 0 1.8 1.8 1.8
7.5684e-009 1.8 0 0 0 0 1.8 0 1.8 0 1.8 1.8 1.8
7.8125e-009 1.8 0 0 0 0 1.8 1.8 0 0 1.8 0 0
8.5449e-009 1.8 0 0 0 0 1.8 1.8 0 0 1.8 0 0
Vv0 A11 0 PWL(time,v11,R 0)
Vv1 A10 0 PWL(time,v10,R 0)
Vv2 A9 0 PWL(time,v9,R 0)
Vv3 A8 0 PWL(time,v8,R 0)
Vv4 A7 0 PWL(time,v7,R 0)
Vv5 A6 0 PWL(time,v6,R 0)
Vv6 A5 0 PWL(time,v5,R 0)
Vv7 A4 0 PWL(time,v4,R 0)
Vv8 A3 0 PWL(time,v3,R 0)
Vv9 A2 0 PWL(time,v2,R 0)
Vv10 A1 0 PWL(time,v1,R 0)
Vv11 A0 0 PWL(time,v0,R 0)
Thanks.
hspice question
you lookat the files:
hspice.out
or
*.lis
in the file, you can find the error message.
Re: hspice question
Hi yen,
Could you please explain what "R 0" means? I can't find this kind of usage in hspice's document. Maybe you mean repeat from 0s, but I can't find a data-driven pwl has such syntax. Remove R 0 and all warnings dispear.
Please correct me if I am wrong.
hspice question
R0 is the resistor
if your hspice model is subcircuit mode, you should change R0 to XR0
Re: hspice question
I guess the warning may be due to the delay value is too small for hspice handling
Re: hspice question
limingchou said:
R0 is the resistor
R 0 is definitely not the resistor here:
Re: hspice question
What is the R0 means in the statement.
hspice question
R 0 may represent for repeating from time 0 in pwl:
VV0 A11 0
+ 0 0
+ 7.3242e-010 1.8
+ 9.7656e-010 1.8
+ 1.709e-009 1.8
+ 1.9531e-009 1.8
+ 2.6855e-009 1.8
+ 2.9297e-009 1.8
+ 3.6621e-009 1.8
+ 3.9062e-009 1.8
+ 4.6387e-009 1.8
+ 4.8828e-009 1.8
+ 5.6152e-009 1.8
+ 5.8594e-009 1.8
+ 6.5918e-009 1.8
+ 6.8359e-009 1.8
+ 7.5684e-009 1.8
+ 7.8125e-009 1.8
+ 8.5449e-009 1.8
+ R 0
But in data driven pwl, I don't know this kind of usage.
