hspice no convergence
tofu
Newbie level 5
Newbie level 5
no convergence in operating point
I'm running transient in hspice and unable to get the circuit to converge.
**warning** Due to a floating point overflow problem,
the damped pseudo-tran method was used.
Also, gmindc was set to 1.0000E-11
**diagnostic** time step too small in pseudo tran. delta= 8.8818E-19
no convergence in damped pseudo-transient, trying gmath ramping method
**diagnostic** no convergence in gmath method gmath= 0.00
**diagnostic** begin gshunt ramping
**diagnostic** time step too small in pseudo tran. delta= 5.8208E-19
**diagnostic** time step too small in pseudo tran. delta= 4.2333E-19
**diagnostic** time step too small in pseudo tran. delta= 3.0043E-19
**diagnostic** time step too small in pseudo tran. delta= 2.6234E-19
**diagnostic** time step too small in pseudo tran. delta= 9.8683E-19
**diagnostic** time step too small in pseudo tran. delta= 9.5827E-19
**diagnostic** time step too small in pseudo tran. delta= 9.4461E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3792E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3461E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3296E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3214E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3173E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3153E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3142E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3137E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3135E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3134E-19
**diagnostic** time step too small in pseudo tran. delta= 9.3133E-19
**diagnostic** although this circuit has failed to converge
to gshunt= 0.00 , it did converge to a gshunt= 1.000E-03
**error** no convergence in operating point
*** hspice diagnostic ***
nonconvergent voltage failures= 0
nonconvergent element current failures= 0
Here's my TRAN section :
.TRAN 1.00000E-10 14.00000E-08 START= 0.0000
.TEMP 25.0000
.OP
.save
.OPTION WL post probe opts ACCT
+ PROBE=0
+ DELMAX = 1.00000E-09
I tried RELTOL=.01 ALTINT=1 and other options but none of them seem to work.
What else is worth trying?
Any help is appreciated. :D
no convergence in operating point hspice
deleet ACCT and DELMAX
add accurate=1 method=gear
maybe it can pass.
gshunt ramping failed
try increasing ur run time to some microsecs.
no covergence in operating
thanks for the replies but none of the helps. ;\
check your circuit first to be sure correct connections.
Is your circuit working with a very short time pulses or expeted very high slew/rates ?
delmax in hspice
.TEMP 25.0000
.OP
.save
+ PROBE=0
change the algrithem.
no convergence in operating point +hspice
try using the following .options
I didnt have time to pick out the options. But just use this in ur sim and let me know if u still have probs.
.OP ALL
.OPTION ACCT NODE OPTS LIST LIMTIM=50
+ GMIN=1.00E-12 RELTOL=0.01 ABSTOL=1.00E-12
+ VNTOL=1.00E-06 TRTOL=7.00E+00
+ ITL1=400 ITL2=100 ITL4=100 ITL6=100
+ LVLTIM=2.00E+00 TNOM=+2.50E+01 LIMPTS=99999
+ CHGTOL=1.00E-14
+ MAXORD= .20E+01
+ METHOD=GEAR
+ DELMAX= .00E+00
+ POST
+ CONVERGE=1
Added after 1 minutes:
take out ITL6 = 100, if it is not identified by ur simulator. It depends on the version of hspice u r using.
gud luck
Re: no convergence in operating point
.TEMP 25.0000
.OP
.save
+ PROBE=0
