HSPICE monte Carlo simulation error
Full Member level 4
Full Member level 4
When I use monte carlo command in hspice, hspice generated log file with error statement like this.
**error** no difinition for 0:monte
it was called by 0:tr1
what does it means?
I used hspice 2006.03. Netlist I written is like this.
.tran 1u 230u monte=10
.probe v(*) i(*)
I don''t know why hspice can't work properly.
thanks.
Could you please tell me the difference between monte carlo analysis and corner analysis?
Because my company never use monte carlo , when I asked my boss , He said, corner analysis is enough.
Thanks
    020170
Dear 020170,
You should add the keyword "sweep" before you determine the Monte Carlo iteration numbers. (like this:)
.tran 1u 230u sweep monte=10
Regards,
EZT
    020170
