lucas_severo
Newbie level 3
I am trying to simulate an analog circuit in hspice linux. I am using the parameters of IBM 0.13um CMRFSF process.
The Hspice not run due some VA compilation problem.
In the .lis file the following mensage is shown:
*pvaE* Please invoke hspice script instead of binary.
**error** call to epvaHDLinit failed.
**error** Failed to read verilog-A file.
**error** (teste.sp:3) difficulty in reading input
How can I solve this problem?
If I run this simulation in a windows platform the simulation don't have problems, but the following warning is displayed in .lis file.
**warning** *pvaW* parameter m is not treated as a mfactor or $mfactor (./IBM_CMRFSF_130nm_HSPICE/models/././gsnap.va:10)
**info** *pvaI* Hierarchical Verilog-A (HVA) instance has been detected: esdnsh_spe (./IBM_CMRFSF_130nm_HSPICE/models/././esdnsh_spe.va:8)
**info** *pvaI* spice primitive detected.
What is the problem? Any solution?
Thank you.
Thank you.
