ericliu said:HSIMOUTPUTVRES : Controls output voltage resolution. default value=1mv
HSIMOUTPUTIRES : Controls output current resolution. default value=1nA
HSIMOUTPUTTRES : Controls output time resolution. default value=1ps
The most important thing is the setting of HSIMOUTPUTVRES.
andy2000a said:hsim default output is "fsdb doemat" --> .tran simulation
but if you use .AC simulation , nWave can not display , I don't know why ..
hspice output is .tr0 , use nWave will auto convert it to .fsdb format
which nWave version ?? some old nWave ( < 5.0) can not open new version ... and X86 PC version nWave also can not open
Unix version .fsdb file
cin said:The most common HSIMPARAM i used for the subckt blocks in the full-chip simulation are:
HSIMSPICE, HSIMANALOG, HSIMGCSC & HSIMAMOS
for subckt that contain pumps & regulators such as charge pump, i usually set HSIMANALOG to either 2 or 3.
Other paramters I used are:
HSIMTAUMAX, HSIMOUTPUTFLUSH, HSIMDCITER, HSIMTIMESCALE, HSIMCKEEPELEM, etc
I usually set HSIMSPEED to 3 or 5 for fullchip simulation. Never used HSIMSPEED=8 though as N@ssd@ guys can't guarantee the result
shiowjyh said:Hello,
Did anyone do comparison with hsim and hspice or other eda tools?
In analog circuit, the result seems like not a trustable one...
And, anyone try digital or mixed mode??
Regards,
