tsinghua
Full Member level 4
ic5141´øaaim hsim
I can use AAIM-05222006 with hsim6.0 without any problem. When the AAI is updated to latest version AAIM-08232006, it does not work any more. The error message from CIW is as follows.
*Error* eval: unbound variable - HSIM_CDSENV_TB
It seems that the environment variable HSIM_CDSENV_TB should be defined. But I do not know which value this variable should take.
It is weird that after the upgrade it can work by still keeping the environment variable NASSDA_ARTISTIF pointing to the installation dir of the old AAIM-05222006, even if I had unstalled the old one from and installed the new one into the IC5141 dir.
Please advise the meaning and purpose of HSIM_CDSENV_TB.
Thanks!
Thanks!
