howto determine the FIFO Depth
arunapai
Junior Member level 2
fifo design
Hi All,
I have a design issue, I have an interface between two domains:
Input is a 16 bit parallel data at 500MHz
Output is 1 bit serial data at 50 MHz,
I need to maintain my throughput at 500Mbps.
For this scenario, I need to design a FIFO.
Can anyone help me with the FIFO design, especially the FIFO depth?
Thanks,
Arun
Re: FIFO Depth
Thanks,
The concept was clear, but I am not able to related it to my design issue.
Can u pls work out the FIFO depth for me?
FIFO Depth
I need to maintain my throughput at 500Mbps?
May you explain it more detail ?
Re: FIFO Depth
arunapai,
In this scenario, your FIFO can't work.
Always the output must be faster than input. If not, FIFO will be fulled and then lost data.
500Mhz x 16 bit = 8000 Mbps at input. And you have 50 Mbps at output.
FIFO is only for temporally stops in output channel. Not for lowest speed output.
FIFO Depth
"I need to maintain my throughput at 500Mbps
Output is 1 bit serial data at 50 MHz,"
cosidering this two statements
FiFo output width is 1 and clock is 500Mhz.
"Input is a 16 bit parallel data at 500MHz "
this is not fully explained.
could be two cases
1. Continuous flow of data????? Answer is very bad . you can't have a fifo working here..
2. 16 bit parallel data at a clock of 50Mhz but in burst mode. and throughput of data is 500Mbps/slower.
then you can have the fifo with full or programmable full signals. and use the ref. given by "shanmugaveld" to calculate the depth.
hope it helps.
FIFO Depth
Lets consider the other way around.
Input is 1 bit; clock is 500 Mhz.
Output is 16 bit ; clocked at 50 Mhz.
what should be the fifo depth?
Re: FIFO Depth
Here is the answer.
input 500Mhz 16 bit
Output 50 Mhz 1 bit
Let us consider 500/50 = 10 .
That means 10 clocks of input write, we can only have one clock of output read.
in 10 clocks, How many data it can able to write = 10*16 = 160 bits.
In read side, we have only one clock. It can able to read = 1 bit.
FIFO Depth = 159.
But clocks are asynchronous, we can round upto = 160/
FIFO Depth 160
-RAM
Re: FIFO Depth
No, this is not correct .. If input is faster than the output and there is no silence interval, the FIFO can't be a solution.
Suppose you insisted on using a FIFO of depth 160 bit. What happens after the first time it gets filled ? .. I will tell you:
1. At the output, only one bit is read and the FIFO occupation becomes 159bit and only one bit becomes available for the next 16-bit to be written .. this means that the data at the input won't find a room to be written to.
2. If you want to operate a FIFO here, then you need to have a silence interval to let the FIFO gets empty before you fill it again.
