How would you connect an arduino to a PC wirelessly?
check this link
https://playground.arduino.cc/Learning/Tutorial01
or
see this module datasheet - XBee™ ZNet 2.5/XBee-PRO™ ZNet 2.5 OEM RF Module(pdf)
After a bit of research it looks as though I will need the following:
This goes straight on top of my arduino
This goes into the usb port of my pc and the other end attaches to one of these:
**broken link removed**And there are probably some jumpers or switches that I need to set to determine which is the master and which is the slave?
Is this correct?
