thiagofinottimoraes
Newbie level 6
Hello,
I am considering using LP2980 LDO to supply DC power to a thermistor excitation and reading circuit.
Although it is a very simple circuit, I am short on space and need tight voltage accuracy (tolerance +-0.5%). LP2980 seems quite attractive in its price range. However, LP2980 datasheet (pg 10, attached) suggests not using ceramic capacitors below 2.2 uF in the output, since low ESR values could unbalance frequency stability of the circuit.
I am also using OPA340 Op amp., and it requires a 0.01uF ceramic capacitor bypassing DC supply (datasheet attached, pg 8). Then I got trapped! Tantalum caps won't go down as 0.01uF and film caps have even lower ESR.
It looks like I got out of option in this configuration. So I pose two questions:
1) OPA340 datasheet asks 0.01uF bypassing DC supply, but how bad/unreliable would it be if I use 2.2uF?
2) LDO's can be quite ineffective for many applications if it really can't drive ceramic bypass caps in the 100nF range. Do you have any thoughts/experience on that?
EDIT: Sorry, maybe it would had been better to post this in Analog Electronics section!
