How would I measure Power Factor?
Fiann
Newbie level 6
Newbie level 6
how to measure power factor
I'm working on a Digital Wattmeter project, where the wattmeter is plugged to the mains, and an appliance is plugged to the wattmeter.
My question is, is there a way to measure Power Factor accurately?
I have heard of a Power Factor IC, which conveniently measures the power factor when connected. However, I could not seem to come across it.
measuring power factor
You're possibly referring to power metering IC, e.g. Analog Devices ADE 7753.
where to measure power factor
ADE7753: Single Phase Multifunction Energy Metering IC with di/dt Input (Serial-Port Interface)
What does a "di/dt" input mean?
A di/dt sensor detects changes in magnetic field caused by ac
current. The use can be to sense the "Current" by using a analog/digital integrator .
how do you measure power factor?
The best way to figure it out is to continue ADE7753 datasheet lecture after the two title lines. It has a detailed
explanation of this current sensor type's operation principle. Furthermore di/dt current sensor is a configurable option.
The chip can work with other sensor types as well.
