How works volume OSD in a tv
marco antonio
Member level 3
Member level 3
Peru
I want to know how the volume is controlled in a Tv with an OSD since when I need to increase/reduce the volume, the bar is displayed on the screen but how is the path it follow from pushing the switch until heard the sound.
rgds
marco antonio
OSD is just a display indication of the volume setting, the actual volume is controlled by some circuitry in series with the audio path that can attenuate the audio signal. The setting of the attenuator is also passed to control some digital circuits that can overlay graphics onto the video to display the volume setting.
So when you push the volume up button the microprocessor or other logic increments the volume setting at the attenuator and also changes the digital setting of the OSD.
Is that the level of detail you are looking for?
Ray
Ray
Thanks for your response and I will appreciatte if you have some more detailed info with an example.
rgds
marco
For the actual volume control this is typical of the chips used:
And for the OSD part see this Wikipedia entry:
On-screen display - Wikipedia, the free encyclopedia
And here is a chip that does the all of the OSD part:
Then there is the microprocessor that accepts the buttons or IR control and send the volume data to the volume chip and the OSD data to the OSD chip.
To go into any more detail I would need more information as to the application or more specific questions.
Ray
