how will you place 10 pnp transistors?
holddreams
Full Member level 6
Full Member level 6
Shanghai
In Razavi's book, Figure 11.20 -----Generation of a temperature-independent voltage.
The configuration has Q1,Q2,Q3 pnp transistors.
As described in bandgap circuit design,the two pnp transistors ratio usually equal 8:1,so when doing layout,we can place the pnp transistors like the following,
A A A
A B A
A A A
But in Figure 11.20, if Q1:Q2:Q3=1:8:1,that is total 10 pnp transistors,how will you place these 10 pnp transistors?
Thanks.
I can quite understand what do u want clearly...
How to draw it or how to place the transistor in symmetry...
How a bout
A A
AABAACAA
A A
This is only a bad idea eh... he he
it is area ratio.
so change it to 2:16:2
AAAABCAAAA
AAAACBAAAA
sunking said:
it is area ratio.
AAAABCAAAA
AAAACBAAAA
But if change the area ratio to 2:16:2,the layout area will increase a lot.
Dont worry about it.
Use the min size pnp.
it only a little increase for the whole chip which this circuit is needed.
you can calculate it.
for a bandgap circuit, the pnp will cost the most area.
so if double, the area will increase a lot.
ya u r correct.the way u told i.e
aabaa
aacaa
is the correct way which suits u
The best way is to take 2 dummy pnps and u can plase in 3*4 or 4*3 array.There is one more best way is take 6 dymmys and place 4*4 u can get beat matching and can minimize the stress and temperature effects to aa greater exteny.
The main points when BJTs matched:
1.Aspect ratio
2.Gradient cancellation
Gradient cancellation my be done with normal centroid based arrangement.But still
u have options.
1.AABAA
AACAA
The above configuration saves the area BUT by increasing mismatch.
ASPECT RATIO: 5:2 =2.5:1
Ideal aspect ratio is 1:1.DON'T PROMOTE MORE THAN 1:2.
2. Du A A B
A A A A
C A A Du Du=Dummy
The above configuration increases area by reducing the Mismatch greatly!!!
Aspect ratio:4:3=1.33:1
With smaller contributiontion to the mismatch from aspect ratio part.
3. The same pattern can be implemented to reach the Ideal aspect ratio
1:1.BUT by increasing area parasitics&noise.Having 4:4 for better match is not optimal solution.
Regards
Mahendra
