dhakeparag81
Full Member level 2
hello,
I need some clarification or say some knowledge which i didnt able find out.
Lets say there are two node in can bus having id 101 and 102, when node 101 communicating it sending its id 101 right? and same for the node 102. i mean unlike MODBUS, in modbus master sending the slave id for communication,there is no slave in CAN bus.
now if node 101 having temperature data which is require by node 102, then when 101 is communicating it will send the id of its own 101 then DLC then data which contain temperature data then other stuff, in node 102 it received the data form 101 and act on it accordingly.
