pusparaga
Full Member level 4
Dear Sir,
I have taken the Avago ATF54143 transistor and designed low noise amplifier (LNA), simulated S-parameter and Noise Figure values at 1GHz as follows
S11= 0.581(Mag) and 19.2444(Angle), S21=10.412(Mag) and 179.792(Angle),S12=0.046(Mag) and 139.669(Angle),S22=0.363(Mag) and 51.049(Angle),NF(Noise Figure) = 0.543dB, NFmin=0.36dB.
At 1GHz , transistor ATF54143 has the following noise parameters
Fmin= 0.22dB, Γopt(Gamma Optimum)=0.32(Mag)67.6(Angle), Rn/50= 0.04.
Numerically , we can calculate Noise Figure (NF) using following attachment formula
My question is, how to calculate numerically Noise Figure (NF or 'F' in the attached formula) and Γs( Gamma S). Whatever we are calculating numerical Noise Figure(NF), that should be closer to the simulated noise using the S-parameters as NF=0.543dB. I kindly request someone help me , how to numerical calculated Noise Figure as closer to the simulated noise figure NF=0.543dB.
