how to write data to code memory 8051
cheenu02
Junior Member level 3
hi,
I am trying to save my datas in the code memory of P89v51RD2 controller.I am using KEIL s/w.how to do it?
Help me..
thank you,
srinivasan
in C you can use the data type "code"
ex. unsigned char code a[10] = ....................
unsigned int code a=10 or strings can be passed using word code. it will go to you flash memory.
I tried with that one But It is showing warning.
Below is my example program and warning displayed.
#include<p89v51rx2.h>
void main()
unsigned int code a=10;
while(1);
MEM_TEST.C(6): warning C280: 'a': unreferenced local variable
I want to assign the particular memory address in code memory and I want to read/write data from that memory area.
Declare the a outside the main function,
or make it a global variable it will work..
Example is shown below
void main()
while(1);
while linking it is showing the following errors.Do I need to change any settings in KEIL compiler?
Build target 'Target 1'
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?CO?A
Program Size: data=9.0 xdata=0 code=19
"a" - 0 Error(s), 1 Warning(s).
Actually this warning occurs because you haven't used a in your program..
When you will use a no warning will appear..
void main()
unsigned int i;
i = a;
while(1);
Hope this will work
