How to write a logic in Verilog for creating a latch?
r_p_sanna
Member level 3
Member level 3
if i have to write a logic for creating a latch in verilog, how do i do it ?
latch verilog
Its very simple ...
here it goes
module latch(
   // Outputs
   dout,
   // Inputs
   din, le
   input din;
   output dout;
   input  le; // latch enable
   reg dout;
   always @(din or le)
     if (le == 1'b1)
       dout = din;
endmodule // latch
latch in verilog
thanks. i was thinking in lines of, if i don't create the default in case statement, latch is inferred. is there any other way that a latch can be inferred ?
verilog inferred latch
in three case:
1. if no else
2. sensitive list is not complete
3. case condition is not full
    r_p_sanna
latch verilog code
instead of using
always @(posedge clk)
try using
always @(enable)
a latch is trigger by signal other than clock :)
verilog latch model
hi,
sensitive list not complete can not produce latch, when simulating , it behaves just like latch, but after synthesize, it is still combinational logic. it's a differece between simulation and synthesize.
verilog latch code
yes , only if and case can produce latch
latch code verilog
One of the best way to ensure that latches are not inferred is to check all that all the variables being computed in the given block are evaluated in very possible way
Re: latch in verilog
nand_gates' original code should be modified to -
module latch(
   // Outputs
   dout,
   // Inputs
   din, le
   input din;
   output dout;
   reg dout;
   always @(din or le)
     if (le == 1'b1)
       dout <= din;   //Use non-blocking
endmodule // latch
Reference:
From Cliff Cummings' "Nonblocking Assignments in Verilog Synthesis, Coding
Styles That Kill!" -
Pg. 5 -
"Guideline #2: When modeling latches, use nonblocking assignments."
always statement without the "@" symbol is an inferred latch..
module dlatch_reset (
data ,
en ,
reset ,
q
input data, en, reset ;
output q;
reg q;
always @ ( en or reset or data)
if (~reset) begin
q <= 1'b0;
end else if (en) begin
q <= data;
end
endmodule
Re: verilog latch model
IF i don't mention any edge triggered clock in always i.e. always @ (* or x or y or z or ..... ) , then this would produce latch . Specifying "always @ (posedge clk or negedge clk or .... )" won't produce latch.You need to mention this in always , otherwise it is taken as level sensitive n would produce a latch.
hi,
