How to write a hspice code to get in db range?
mya
Newbie level 3
Newbie level 3
hspice coding
I want to plot a second order integrator in db @yais and frequency in axis. The software that i am using is hspice. pls. tell me what i should write to get in db range.
hspice coding
vdb(node)
or use your plot software to do the transition.
Re: hspice coding
thanks for ur reply. i cannot get the response graph in db. It 's in mag. only.
The one that i want is in mag. response graph and phase graph.
.ac dec 10 .001 10k
vin in 0 ac 1
.plot ac vdb(op1)
is it right?
Added after 3 hours 2 minutes:
Is BW of the integrater related to THD?
Is phase margin of the integrator related to THD?
when i run the hspice, the phase plot is ascending from 180 degree. the one i am using is 2nd order integrator.
hspice coding
vp(node) will give you the phase plot.
hspice coding
If you want a continuous phase plot at 180 degree, you should add a option unwrap:
.option unwrap=1
.probe ac vdb(op1) vp(op1)
Re: hspice coding
i can get the Bode plot. In phase plot , the graph shows that it is ascending from 180 degree. The one that i am using is non-inverting op-amp. I don't know how to interpret that graph.
Is THD related to Phase margin?
