How to work with Keil compiler
tocal09
Member level 3
Member level 3
I'm learning 89c51 and using Keil but it's help too simple . Where I can get the guide&help (everything) more usefull (I've used ASM before don't kown much about C language)
the C51 Compiler User's Guide has 400 pages, the Assembler / Linker User's Guide 450 pages and the uVision User's Guide 230 pages. I think these PDFs are not too bad and treat a lot of details concerning the compiler. But i agree that the Keil documentation is not a C course. Perhaps you should start reading a general C book like Kernighan/Ritchie.
Mik
How to work with ke*il compiler
Search for "C51 Primer". This book is for Free. And it is the best one for Keil C.
Salam,
C51 Primer
Bye
What's the difference : programming C for microcontroller <---> C which we usually use for PC (who can compare them for me )
As long as the C is ANSI-C, I guess are the same.
I have done C for PC before, and then I move to C for MCU, and I did not facing problem.
Sis
Just remember, that in uC world you have very limited resources, especially memory. Therefore, it is near impossible to write project in pure ANSI-C without so called, language extensions. I recommended C51 Primer book above. It has extensive description of differences between ANSI-C and uC-oriented C modifications.
Beside at keil.com where I can get more example code ?
Hi tocal09,
I guess Ke*il has to much samples code, and i think that's enough for learn. After You try those samples, and then You facing a problem, You can ask/share on this forum again. This forum is the best.
Sis
There are a lot of source codes on Internet,in this forum or some forum for 8051,8052 ,for example http://www.8052.com
Cheers,
