kk027
Newbie level 5
Ok, I have a motor which I think as per my inspection had bad contact plate and the owner was throwing it away. has no smell so I am trying to fix it up He had pulled start capacitor and run capacitor out and lost them. So I brought new contact plate, capacitor and need help wiring.
1. Two wires (120V each) are going to two different winding on left side.
2. On right side two wires from one winding and two from another is coming. It seems one from each was going to run and other to start capacitor. I could be wrong does not want to wire incorrect.
3. So based off these four wires I want to connect run capacitor and start capacitor. I have good electrical background, but this I have not done this before.
4. I need help determining start winding, run winding. Once I know these I can attach centrifugal switch and contact plate. Start capacitor will start the motor using start winding and as it speeds centrifugal switch will break that contact and make contact with run capacitor and run winding, that I know.
Thank you for help, let me know what I need to do.
