vcs dump memory contents
what version of vcs u r using?
vcs comes in 2 gui, virsim and dve.
if you are using dve, there wont b any problem. follow the steps below:
1. vcs -debug <your filename>
2. simv -gui
it will bring up dve. at first glance you cannt c your mem
use ur mouse right click on the signal in hierarchy panel (the left most one), choose "add dump", in the dialog, check Aggregate.
you have to re-simulate your design under dve - Simulator -> Rebuid & start, then you will c ur memory instance now!
BTW, anyone know how to display using Virsim? I only know how to do it in dve.
