JDW_
Junior Member level 2
I designed a circuit that operates on both 12V or 24V vehicles (my 150mA-max output voltage regulator steps 12V or 24V down to 3.3V for an MCU and other digital circuitry). I also need a relay on the same PCB, and the MCU will use a transistor to switch the relay ON/OFF via the relay coil's GND side. Normally, this is very easy when dealing with a single voltage like 12V only or 24V only. I would just choose a 12V or 24V relay and pull the coil's high voltage from Vin before my voltage regulator. But in this application, I need to use the same device on both 12V cars and 24V trucks. I cannot use a 24V relay coil on 12V because it just won't switch. And using a 12V coil on a 24V circuit would fry the coil because I need to keep the relay power for long periods of time (during the entire duration the vehicle is being driven).
I could use jumpers to add a resistor in line with the relay coil, but that relies on the human element. If this device is ever mass produced and professionally installed, installers would without a doubt forget to set the relay coil jumper, and such would result in blow coils and complaints. So I want to avoid jumpers as a solution to this problem. I am wondering if there is a solution that is fully automatic and doesn't relay on the human element to adjust the relay coil voltage.
Thank you.
Thank you.
