how to use the parallel port to control 9 or more device
parallel port
  • parallel
    Votes: 0 0.0%
  • hehe
    Votes: 0 0.0%
  • Total voters
buckboard
Newbie level 2
Newbie level 2
pcf8574p output register
how to use the parallel port to control 9 or more device indepedently....
help i'm thingking about this device to save electricy by using a controller (parallel port). the problem is i can only control 8 device at a time...
what i'm trying to do is to control 9 or more device independenty using he parallel port....
pls help me how....
any sugestion will be appriciated...
thanks..
hi
u can use multiplexer and tristate buffer for control your devices
With 8 data lines, 255 devices can be controlled (255 lines) by multiplexing the lines as 2^8.
from 00 to FF you can control.
To control several dvices via the parallel port don't use multplexers and/or buffers, as they work "momentary" .. you need latches ..
One option is to employ 8255 PPI ..
Here is an example:
"24-bit parallel port interface with 8255"
https://jap.hu/electronic/c64pio.html
Google for more ..
Regards,
IanP
You can use the parallel port's 8 data bits plus one of its control bits to give you 9 bits. General info here:
If you don't need high speed, another approach is to use a shift register such as 74HCT594. It provides eight outputs, and includes an output register. You can easily chain multiple devices, all controlled by a few wires. Here's a data sheet:
http://www.standardics.nxp.com/products/hc/pdf/74hc594.74hct594.pdf
Here is one of my designs a schematic of four 8-bit ports interfaced to the parallel port
spy h / spy i is a single wire but can control n number of devices.
