How to use the Maestro software for PIC?
aym_qunibi
Member level 4
Member level 4
please i want to know how to use the meastro software for pic?
Re: meastro...?
It's quite well documented, once you know where.
After installing the Maestro software, look in the /modules folder. It contains folders for module and in those folders is a .pdf document to read, along with the prototype module code.
A quick run-through:
1. Launch Maestro
2. Drag the module name you want from the list into the "Selected Module" box
3. Double-click any parameters you need to change in the "Value" column
4. do Tools/Generate Code
5. You will be prompted to point to the folder you want the files in
6. You can now examine the files in that folder - there is a .c file to load into your source, it calls a .h file. There is also a copy of the .pdf document (instructions in here) and an example program you can compile to test the module.
Hope this helps.
Cheers,
FoxyRick.
    aym_qunibi
Re: meastro...?
please if you have more docs then upload it..
