how to use the integrator in the calculator of cadence?
katrin
Full Member level 1
Full Member level 1
iinteg cadence
Hello,
I want to know the integration with time of my output signal in the time domain
The calculator in the cadence provides the integral function-- integ
When I select the output signal in the calculator and then click integ
it shows the form--Definite Integral
Signal: already filled with my output signal
initial value: ?
final value: ?
I want it to display a signal waveform which is the time integral of the output signal between 0 and 3 ms
But instead it only shows a number
So I suppose I have not filled the box initial value and final value as their correct way
Could some one tell me how to use this integrator function exactly?
or is integ the correct function to use?
integration in cadence calculator
I think that this function just "calculates" the value of the definite integral of the given signal on the specified interval. I don't think it can be used to draw the integrated waveform.
A very simple way to do so is to define a simple veriloga model that performs the function 1/s.[/b]
    katrin
    gaurav8171
iinteg calculator
thanks, but I still don't really know how can I define a veriloga model in cadence for integration
cadence calculator integ
u should use the iinteg "indefinite integration function"
cadence iinteg
thanks a lot
