how to use the ile and il files in cadence 5033?
tuza2000
Full Member level 2
Full Member level 2
i have download some skill language files which name are *.ile or *.il
how can i use it in layout ?
Added after 2 hours 10 minutes:
nobody can help me?
It depends on how the program is designed. But all begin with a load in CIW.
load("download.ile")
how does the ciw know where to load the "download.ile"
where should i put the "download.ile"?
or i can put it anywhere and compile it ?
please
thanks
you may put the file in your current working director, then, use load("filename").
If you put it in a different directory, then, just add the path.
    tuza2000
i see ,thank you!!
it just like matlab.
i will try it!!
