how to use relay to drive LED by using micro-controller.
saba.asif
Newbie level 2
Newbie level 2
plz tell me that how to use relay. i want to drive led by using relay. input to relay is given by micro-controller.
why you want to use relay ? what is the power of the LED that you want to use ?
If you need to drive a LED or a relay from a microcontroller, you need a driver circuit.
One of such circuits use a "logic MOSFET" which s controlled by uC logic output, and can switch a larger current (10A) under a higher voltage (up to 60V). I use IRF 540 in such circuits.
Google IRF540 for a data sheet and application circuits. It is simple and you need only a small heat sink for currents >2 A.
Please check the attachment. It may help you.
I'm not sure why you need a relay to glow an led.
There are very easy methods to glow the led.
1. You can connect the led to uC pin through a resistor.
2. else, Using the transistor or mosfet.
  • Sheet1.pdf
it is not evident that he can connect the LED to the pin of the microcontroller, it can be that the microcontroller cannot sink the current required by the LED
