Deboshree
Newbie level 1
I am working on phase codes (examples - Frank, P1, P2, Zadoff Chu) to generate minimum side-lobes on matched filtering. I considered a sinosoidal carrier wave at 45 mHz45 mHz, and phase modulated with 37 bit Chu code. The image shows the resultant wave
I want to generate a similar signal with a sequence of pulse with carrier signal at 45 mHz45 mHz.
Modulation like pulse position modulation are possible?
And will they be conceptually correct ?
If yes, then how to do them ?
The resultant signal will be used to modulate an optical source.
