How to use PDK in cadence
zzd135
Newbie level 3
Newbie level 3
HI,
I have a PDK of XFAB. How to set it in cadence. Anybody help me.
regards
Most PDKs have two site customization files namely: cds.lib and .cdsinit
the first loads PDK components in your library-path and therefore appear in library manager to use. The other file includes a set of SKILL commands to be loaded to customize the tools in certain way or to add some functionalities related to the kit, such as adding pull-down menus, buttons, ...
So, look for these two files, and simply, run the icfb from the same folder where they exists.
I hope that helps you.
Regards,
Ahmad,
Thank you very much , I have resolved my problems.
Regards
Hi zzd135,
HI, it such a longtime from your pose but today my professor gave me a XFAB PDK, I installed but when I run the script" tkit" the error of "command not found" exit.
Could you tell me the process to set XFAB in cadence?
Many thanks
HI test_out
You will have to first set the working directory to the location where the "tkit" command is found.
Then, set the T_DIR and CDSDIR variable to their respective locations, rather set the path for their location.
Then, run the command. It should run on its own.
Regards
Javed
Hello test_out, sorry if I did not post any help in time.
I expirence a familiar problem and the solutions for me was to
add the comand ' INCLUDE $T_DIR/cadence/env/templates/cds.lib' at cds.lib
file that is locaded in the working directory (project file).
Hope that may help you!!!
Guys,
Could someone advise how to set the CDSDIR? I mean which directory should it be?
I go to tkit directory and try to run the command but have the following error "command not found"
---------- Post added at 16:05 ---------- Previous post was at 15:56 ----------
Hi ririkos,
I have advanced a step further by your comment. Now I have the error "cadence executable not found". Do you have any suggestion?
Thanks in advance
Hi dear all,
For installing gpdk090 i find this site very helpfull: **broken link removed**
To be helpfull.
Good luck.
