Wht to change in the power supply to charge 12 v 40A battery??
wht to do plz explainsince both are dc voltages you may use a dc dc converter to boost your voltage op
use of DC to DC converter..
Just search EDABoard forum, recently we have thread about that, I post several examples PC PSU to 13,8V-14,4V. There is no point to duplicate threads.
By the way what battery you will try to charge at 40A ?
You know that lead acid will pull high current from charger specially when starting to charge empty battery you need to limit current somehow, or PC PSU will shutdown or you will have fire. Fire or shutdown depends from which China factory is made that PSU.
the battery is 40A battery all i need is morethan 4 amps i think
i wil look about the thread
thx
I have impression that on EDABoard people have "SMPS mania disease" and they dont know when to use switching and when regular parts. All can be done on any way, and all is possible, but design should be simple and effective.
janosandi, it depends upon your power supply under use, whether it has and adjustment or not. If it is not already in the circuit embedded facility then it may be bit difficult to do it without having enough knowledge of the computer PSUs. (Thats my assumption, you may be having enough knowledge about it).thx for ur replys
how to adjust the 12v to 14 v Mr Raza?
as every one here share his/her own experience and tries to guide the help seeker.
you skip something, original post say to charge 12V 40A he didnt say 40Ah of battery capacity
I was able to pick what he meant and was right on my assumption.
