how to use msa patch calculator in em talk
What it means is the radiation resistance at the edge of the patch. and the value is in the order of few hundred ohms depending on the size of patch dimensions and substrate used.
Hope that helps
Regards
ChachitoEL
hi
thanks for reply
can u answer me how to calculate the feed point for microstrip patch antenna
and as you wrote" and the value is in the order of few hundred ohms depending on the size of patch dimensions and substrate used"
what should be the optimum value for that and how it is used in designing an antenna
regards
kartik
There is no such optimal value(Radiation resistance determines the power that is radiated by the antenna,Higher the better) and you can do feed point for the patch using the equation presented in the balanis book or send me over your microstrip patch design,i will do it for you.
Regards
ChachitoEL
thanks
i want to know if the feed point calculations will differ for rectangular ,circular,fractal and stacked microstrip antenna
and which book to refer for these or a online calculator is available
kartik
---------- Post added at 07:12 ---------- Previous post was at 07:11 ----------
thanks
kartik
---------- Post added at 07:13 ---------- Previous post was at 07:12 ----------
sorry for the repost
also i wanted to learn microstrip antenna designing by hfss thoroughly
kindly guide
Feed point calculations are fairly simple for rectangular and circular patch antennas,you can refer to the equations in many a texts.
when we get to fractals the theme gets rather unexplored and you will have to depend on findings from the journal articles.
there are a plethora of stacked microstrip antennas,some are easy to formulate some arent.
if you want to learn antenna design using HFSS then you will have to start desinging from scratch, there are a plenty of examples in the HFSS manual.
Regards
ChachitoEL
