I think ur problem is "ur mic". You had checked the spec. of microphone, in my experience, some microphone can only respone to sound in uni-direction, and sound (voice) should be very close to mic to record, otherwise the volume of sound is "small". If you want to record your piano a distant from your mic, you had better buy another mic which like used in karaok.nimnorm said:Using xp. My voice ok when near microphone, but piano not near and weak sound in recording. Tried mute line in and others...no luck. Where is equalizer?
