cllunlu
Member level 4
Hi everyone,
I wanna use interrupt on change IOCC1 and IOCC2 pins to read button. These pins are logically high, when button is pressed, it will be logically low and interrupt routine will run. But my code that is below doesnt work. Program doesnt run Interrupt routine any time.
Where is my mistake. Can you help me?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 sbit SW1 at RC1_bit; sbit SW2 at RC2_bit; sbit SW1_Direction at TRISC1_bit; sbit SW2_Direction at TRISC2_bit; sbit LED0 at LATA0_bit; sbit LED1 at LATA1_bit; sbit LED2 at LATA2_bit; sbit BUZZER at LATB3_bit; sbit LED0_Direction at TRISA0_bit; sbit LED1_Direction at TRISA1_bit; sbit LED2_Direction at TRISA2_bit; sbit BUZZER_Direction at TRISB3_bit; #define INPUT 1 #define OUTPUT 0 #define LOW 0 #define HIGH 1 void init() { CM1CON0 = 0x00; CM2CON0 = 0x00; ANSELA = 0x00; ANSELB = 0x00; ANSELC = 0x00; TRISA = 0xC0; TRISB = 0x00; TRISC = 0x00; PORTA = 0x00; PORTB = 0x00; PORTC = 0x00; LATA = 0x00; LATB = 0x00; LATC = 0x00; SW1_Direction = INPUT; SW2_Direction = INPUT; C1ON_bit = 0; C2ON_bit = 0; IOCC = 6; // set RC1 and RC2 interrupt on change to ON INTCON.RCIF = 0; // Clear interrupt flag prior to enable INTCON.RCIE = 1; // enable on change interrupts INTCON.GIE = 1; // enable Global interrupts LED1_Direction = OUTPUT; LED2_Direction = OUTPUT; BUZZER_Direction=OUTPUT; UART1_Init(9600); } void interrupt(void) { //BUZZER=HIGH; if (RCIF_bit == 1) { RCIE_bit=0; GIE_bit=0; if(SW1==0) LED1=~LED1; if(SW2==0) LED2=~LED2; INTCON.RCIF = 0; // Clear interrupt flag prior to enable INTCON.RCIE = 1; // enable on change interrupts INTCON.GIE = 1; // enable Global interrupt } } void main() { init(); Delay_ms(50); LED1 = LOW; LED2 = LOW; LED0=HIGH; BUZZER=HIGH; Delay_ms(1500); BUZZER=LOW; while(1) { LED0=~LED0; Delay_ms(700); } }
