How to use Infrared sensor ?
bianchi77
California
Friends,
I want to use Infrared sensor for Line follower robot, but the output of the sensor always LOW,
How can I change it ?
Thanks
Can you specify your IR sensor and IR transmitter ?
If your sensor is 38kHz, do you correctly use 38kHz pulse in transmitter ?
Thanks,
How can I make it "High" it's always "Low", when I lift the car in about 10 cm it's "High"
Is it white line follower robot ?
Why are you using the photodiode in photoelement - voltage mode? It's the least sensitive circuit you'll find and exposing a diode temperature coefficient to cap it all.
How can I make it more sensitive ?
there's op amp circuit in it.. I tried to adjust but no luck
I put white paper facing the sensor and without white paper, it's the same result as in the photos,
do you have idea on adjusting it ?
If nonmodulated DC light sensor is sufficient, you can try this circuit. It works with LM324 and single supply voltage.
I don't have the chip and the PCB I have only LM339 with those sensors.....
I will try to make it work....rather than trying other circuit....
---------- Post added at 14:06 ---------- Previous post was at 14:02 ----------
It works with black duct tape....I tried just now...
