how to use hspics or matlab to imulation eye diagram
shinnyi
Junior Member level 1
eye diagram matlab
the eye diagram like figure1~4
matlab eyediagram
Dear shinnyi :
using these commands:
.param width=period phase=0ns
.probe tran time2=par('TIME+phase-int((TIME+phase)/width)*width')
mpig
    shinnyi
eye diagram sample in matlab
mpig09 said:
Dear shinnyi :
mpig
sorry sir
I have already tried Several time
but it still won't work
can you tell me more about that
*******************************1.25GHZ
.param width=800p phase=0ns
I filter PD_IN pulse(50u 550u 80p 10p 10p 400p 800p)
.tran 1n 200n
eye diagram example matlab
hi
search edaboard
I saw your solution.
regards
    shinnyi
dolphin eye diagram
h**p://tw.pg.photos.yahoo.com/ph/shinnyi2002/my_photos
hi,shinnyi
you can find a demo in this subject, generally, in xx/demo/awaves/demo/eyediag.sp
where xx means hspice root directory
the content of it, in my hspice version, is following
* Eye Diagrams
* This type of diagram is to reduce a large amount of data to
* one frame. Data from a fixed period is superimposed upon
* itself.
* An e source is setup to create a sawtooth.
* The sawtooth period is the window to be plotted, eyewidth. i.e. if
* you are looking at a periodic signal and want to know if the
* period or amplitude drifts over a large time, then the
* eyewidth is set to the period of the data to be plotted and
* superimposed.
* In this example, Y is a damped sin wave at 1 Mhz. X is a 5 Mhz
* sin wave. The eyewidth is set to 2 Mhz. (Look at the difference
* between 2Mhz and 1Mhz as an experiment).
* To view output in Meta-Waves, place signal T on the x axis and plot either
* X or Y on the y axis. For the damped sin wave, notice that the
* frequency is constant but that the amplitude obviously decays.
* This is a view of all periods super-imposed on each other.
* Plot X, Y vs Time,
* X, or Y vs T
* Only 4 lines are needed to add eye diagrams to a circuit:
* Here they are:
* .Param EyeWidth = 2.0x $ Bandwidth
* eT T 0 Vol='(TIME*EyeWidth)-int((TIME*EyeWidth))'
* rT T 0 1k
* .Option Post
.Param EyeWidth = 1.0x $ Bandwidth
* a clever alternative here is to set .Param Eyewidth = '1/<clock_period>'
vX X 0 Sin ( 0v 3v 1xHz )
vY Y 0 Sin ( 0v 1v 1xHz 0s 500k )
* Simple time manipulation to create a sawtooth pattern
rX X 0 1k
rY Y 0 1k
rT T 0 1k
.Tran 10ns 10us
.Option Post=2
.End
young
    shinnyi
eye diagram in matlab
Dear shinnyi :
Sorry, I late to solve your problem.
Please try these following steps :
When you creates a new TIME2 output variable :
*Open the resulting .tr# file
*In the "Results Browser" window, under "Types:" select "Params"
*Under "Curves:" select "time2"
*Under "Current X-Axis," click on "Apply"
*Under "Types:" again, select "Voltages," "Currents" or any other
type of output variable you want to display
*Double click on the desired signals you want to display
*In the viewing window, click on the right mouse button; *select "Monotonic Plot ..."
If you have any problem, give me some message!
mpig
matlab eye diagram
maybe you can try smash
www.dolphin.fr
smash simulator have some function can get eye pattern
