How to use HSPICE trans input file
lordfire
Member level 1
Member level 1
hspice .trans
such as a trans source
v1 1 0 ac 1 pwlfile ******
.tran 0.01n 30n
i don't know the accurate syntax
V1 1 0 ac 1 pwl time1 val1
+ time2 val2
+ time3 val3
+ [R=timeX]
.tran timeStep stopTime [start=startTime]
Anything in the brackets means optional.
i have witten a vector file
i want to introduce it to the simulate source
but it still seems WRONG
v1 1 0 ac pwl file='d:\lib\simsource.txt'
.tran 0.01n 30n
.tran 0.01n 30n
You may use data-driven PWL.
V1 1 0 AC 1 0 PWL (time, vol)
With a data statement as,
.DATA vector MER
FILE='vecfile' time=1 vol=2
.ENDDATA
The vector file 'vecfile' may look like:
1.0e-9  0.0
2.0e-9  0.0
2.1e-9  2.5
3.0e-9  2.5
3.1e-9  0.0
The transient analysis statement is
.TRAN DATA=vector
Another way is to modify the vector file to comply with the hspice pwl source sytax -- Add a line 'V1 1 0 AC 1 0 PWL' at the beginning; and add a plus sign(+) at the beginning of each line which defines time/value pair. Then including the modified vector file to the simulation netlist using hspice '.INCLUDE' statement.
