How to use CAN in PIC microcontrollers
swapgo
Full Member level 2
India
Hi
Has anybody worked with CAN?
I want to use CAN in PIC microcontrollers.
I want some suggestions
Regards
Gopi
pic18f458 source code
Search with google !
pic18f458 how to connect
There are many aplication notes in microchip site!!
simple can using pic, and pca82c250
The dsPic series have CAN. The pic30 compiler library has CAN routines.
dsPic are 16bit proccessors that can clock up to 120MHz. Well worth a look.
cantx canrx
hi
I mean to ask which transevers for CAN?
I am using PIC18f458.
I want a simple CAN transever .
Any suggestions please
regards
Gopi
Re: PIC with CAN
PIC18F458 already has a built-in CAN transceiver. If you are asking for dedicated CAN transceivers, just get anyone that is more readily available, since CAN is a universal specification. Microchip has their own range of dedicated CAN transceivers too. IMO, it's way cheaper and more efficient to use integrated transceivers.
Re: PIC with CAN
Hi Checkmate
You mean to say that I can connect PIC18F458 to another PIC18F458 directly witout any CAN transevever.
So can I connect CANTX CANRX of one Controller to CANTX CANRX of other Controller?
Please Clarify
Regards
Gopi
PIC with CAN
No, you need a can transeiver, Microchip do one that is pin compatable with the TJA1050.
Re: PIC with CAN
PIC18F548 to CAN bus
Re: PIC with CAN
Hi all
can I use CAN for longer length wire ie for 1000 meters.
because its mentioned not more than 300meters
Regasrds
Gopi
Added after 2 minutes:
Hi
I have one more question
IS CAN is superior or RS-485 is superior
Regards
Gopi
Re: PIC with CAN
Hello!
You should read notes about CAN. Generaly you can go over 1km length but then speed is droping with distance.
CAN is defenitly supirior over RS485 with some built in lower layers of protocol.
Regards!
Re: PIC with CAN
RS-485 is just a physical layer specification - it does not specify a
protocol. You can invent a protocol of your own or use some that
is readily available. Even maybe the CAN protocol, if you wish.
Here are some cable length/speed numbers for CAN:
100 meters (330 ft) at 500 kbit/s
200 meters (650 ft) at 250 kbit/s
500 meters (1600 ft) at 125 kbit/s
6 kilometers (20000 ft) at 10 kbit/s
Read more here: https://www.kvaser.com/index.htm
/Rambo
Re: PIC with CAN
Hi all
Great help frm you all.
Now I have framed the design.
I am using PIC18F458 with PCA82c250 CAN transever which is availabe here.
I will upload my schematics and my source code after completion
Regards
Gopi
PIC with CAN
hi guys,
some body have some firmware for CAN protocol in pic18f258, i have some problems for develop a project, ahhh i need the firmware in assembler
thanks
