how to use 2 "clk" in one "process"!! ??
vvsvv
Full Member level 1
Full Member level 1
As to What I know, only one clk may used in one process,
however, I have to use 2 clks in process , how to do it!??????
MAY I.....
cnt_pel_P:process (CLK2, RESET)
begin
if (vref'event and vref= '1' and rts0= '1') or (reset = '1') then
cnt_pel <= 0;
elsif CLK2='1' and CLK2'event then
if (cnt_pel >= MAX_PEL) then cnt_pel <= 0;
else
cnt_pel <= cnt_pel + 1;
end if;
end if;
end process cnt_pel_p;
Thank you for your advice!!!!!!!!!!
sorry! I forget to say something:
VREF is another "clk",
its frequency is much more lower than clk2!!
Fvref = 1/(720*576) * Fclk2
Re: how to use 2 "clk" in one "process"!
You will have to make two processes, one for each clock value, and then you should set up some mechanism to get them synchronized one to each other
MAY I.....
begin
cnt_pel <= 0;
else
end if;
end if;
You can use only a single clock (CLK2) and re-sample the "vfef" to generate a synchronous reset.
See the following example
signal sync_reset : std_logic;
signal vref_sh : std_logic_vector(2 downto 0);
begin
-- generate a one CLK2 pulse width on the rising edge of "vref" after 3 CLK2 period.
begin
if reset='1' then
vref_sh<=(others=>'0');
sync_reset <='0';
elsif clk2'event and clk2='1' then
vref_sh(0) <= vref;
vref_sh(2 downto 1) <= vref_sh(1 downto 0);
if vref_sh(2 downto 1)="01" then
sync_reset<=rts0;
else
sync_reset <='0';
end if;
end if;
end process;
begin
if (reset = '1') then
cnt_pel <= 0;
if (cnt_pel >= MAX_PEL) or sync_reset='1' then
cnt_pel <= 0;
else
end if;
end if;
thanks first!
but, does these code produce the condition that
"if (vref'event and vref= '1' and rts0= '1') or (reset = '1') "??
and what's more,
if I do not want 3 clk2' period delay? I just want to prodece one clk period pluse as soon as the condition is meet with "no delay " ? how to do it then?
thanks again!
The difference is that in my source the"(vref'event and vref= '1' and rts0= '1')" reset is syncronous with the CLK2.
see the attached wave.
>thanks again!
You can reduce the delay (ses the following code) but attention to metastability problems.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY Prova IS
PORT
CLK2, RESET,vref,rts0 : IN STD_LOGIC ;
cnt_pel : buffer integer range 0 to 15
END prova;
ARCHITECTURE SYN OF prova IS
signal vref_sh : std_logic;
constant MAX_PEL : integer:=14;
begin
begin
if reset='1' then
vref_sh<='0';
vref_sh <= vref;
end if;
end process;
begin
cnt_pel <= 0;
if (cnt_pel >= MAX_PEL) or (vref_sh='0' and vref='1' and rts0='1' ) then
cnt_pel <= 0;
else
end if;
end if;
end SYN;
since HDL means hardware description language,
so you got to think does it exist any flip-flop cell with two
clk driving? if not, how come you need two clk in a process?
I doubt?
