How to understand this assembly instruction?
ubuntu_amateur
Member level 4
Member level 4
inl instruction asm
there is several instructions in assembly language:
	movw	$0xcf8,%dx
	movl	$0x80003840,%eax	#
	outl	%eax,%dx
	movb	$0xfc,%dl
	inl	%dx,%eax
how to understand the last instruction? what means "inl"?
could anyone provide the material on assembly instruction set?
Thanks a lot!
You didn't say the CPU type or assembler version, but the b/w/l opcode suffix usually means byte/word/long, which usually means 8/16/32 bit operand. So, "inl" probably means "input from 32 bit port".
to ease understanding the code, I'll just comment it rightaway.
   movw   $0xcf8,%dx              ; dx = PCI address port (this is x86 architecture)
   movl   $0x80003840,%eax    ; eax = address of register 40h, function 0, device 7h, at bus 0
   outl   %eax,%dx                  ; "tell" the PCI device that we want to access register 40h in the next PCI cycle
   movb   $0xfc,%dl                 ; dx = 0xCFC = PCI data port (in x86 architecture)
   inl   %dx,%eax                    ; eax = dword starting at register 40h in the PCI device
This should be clear enough for you :D.
PS: The assembly language syntax is in AT&T syntax and it's an x86 (IBM-PC) architecture code. Look for AT&T syntax tutorial if you feel confused. IIRC, GAS (GNU Assembler) tutorial would be enough.
