How to understand the wisdom to real time kernel?
harrysoin
Junior Member level 2
a realtime kernel
how can i understand the wisdom to real time kernel?
any good idea or book to advise
Re: a realtime kernel
hi,
there are many books on rtos in this forum
just search for it in the EDA E-books Upload/Download section
bye
Fire in the Wire :sm2:
you can read UC os by Labrosse for starters, for advance topics, Linux kernel internals.
Hi
A book called UCOS-ii Real time kernal by labrose Is really a good book to start with.
The first step is to learn programing taking the advantage of Real Time System
after a while you would understand the RT system over view
if you are intrested in Kernel level programing only then do you need to understand this
else in any RT OS write a compact code
well RTOS time factor is very critical the out put of certain process is correct only upto certain time after that the answer is invalid
I guess you follow what i say
Added after 51 seconds:
Added after 11 seconds:
