udhay_cit
Full Member level 6
I have a rogowski coil for 10Arms rating with 1:1500 turns ratio. I'm not familiar with rogowski coils. In Current transformers the specifications will be in primary current to secondary current ratio, but here the ratio is in terms of primary & secondary turns ratio.
1. How to calculate the current ratio from turns ratio?
2. Is it 10 Amps differ from 10Arms?
Please some one provide a good signal conditioning circuit for the rogowski coil current measurement. The datasheet is also attached.
Thanks in advance...:-|
