You can try with exporting EDIF format in workview and inport in Cadence
There are a software called electronic design studio(?) can transfer from or to workview with Orcad and many other format.
Or the very complex method is export spice then inport in ADS then transfer to cadence.
There is an executable program called " edifgrap" by ViewLogic, you can find it under WVOffice directory.
The program will pop up an "EDIF Interfaces" to import/export EDIF netlist/schematic.
BUT, I did not try it by myself.
Wish this information is useful for you.
To export EDIF 200 from ViewDraw :
Select "Tools" from ViewDraw's menu bar, then select "Export EDIF", you
should see a pop up window which is "Edifgraf" for export/import EDIF.
Actually the EDIF function of ViewDraw is supported by e-tools.
The export from ViewDraw & import to Composer is OK, but I cannot
find hierarchical way to transfer a complete design at a time.
Anyone knows how to do it hierarchically ?!
I got a demo version from e-tools but can transfer symbols only.Why ?
