How to transform VHDL code to Spice netlist?
Re: VHDL to Spice
what level of VHDL? In general, the answer is No.
Re: VHDL to Spice
Usually you need a synthesis tool to go from HDL to EDIF. EDIF + cell library can be automatically layed out and extracted as a spice netlist.
Re: VHDL to Spice
To make a spice netlist, you need at least spice netlist for all your digital library cells. Then, you need a gate level netlist.
Then, you may expect to produce a spice netlist.
Then, some ways :
- produce a CDL netlist (spice compatible ... some text processing may be needed), Cadence can probably do it
- Nassda has a tools called v2s to transfer verilog to spice, so you may first have to transfer from vhdl gate netlist to verilog gate netlist
- write your own perl script
