How to transform LC ladder filter into integrator based one?
chinito
Full Member level 2
Full Member level 2
Re: integrator based filter
who can talk briefly about the integrator based filters and their use in the analog/mixed signal design. thanks in advance.
Added after 14 minutes:
better yet, how do you transform LC ladder filter into integrator based filter and what're the pros and cons?
it will work as low pass filter its requirement is high time constant (T1=rc) then that of signal (T2)
what I'm interested in discussing is the reason why one would use LC ladder filter over say OPAMP-RC, GM-C, GM-RC and few other topologies. What if one wants to design monolithic LC ladder equivalent. What are the freq ranges (min and max).
