How to Transform Balanced Port to Unbalanced Port?
mesfet
Full Member level 2
Full Member level 2
Hi All,
I am now designing a transmitter by ML2724 from microlinear. But output port of the chip is a balanced port. What I have is just lumped capacitors, inductors and a 50:50 balun. I wonder if there are any quick ways to transform the balanced port to 50Ohm unbalanced port? Any good articles on this problem?
Thanks.
mesfet+
PS: I am using HP8510C only. I don't have network analyzer with differential port.
You can use lumped Balun at 2.4GHz.
Rgrds,
Hi BigBoss,
I am using chip balun. But my question is that how to design the matching network between the IC output and the input of the balun??
mesfet+
I just find from simultion that the matching network can be designed by traditonal approach, with the unbalanced being monitored. I need verifying if it really work.
Hi mesfet ,
The differential impedance of the chip must be well defined . Then this impedance is divided by 2 and you will find single ended impedance. After that , you can match this divided single ended impedance to 25 Ohm!( because it is divided too )
Fianally you buil up a 50Ohm:50Ohm Balun with discrete components.
Look at your PM , I have sent a document to you.
Good Luck
Hi BigBoss
I have got the PM. Thanks!
mesfet+
