In the circuitry that you provided, how to apply the AC supply on the coil ? means are there the two ends of the coil present ........... ?
What should be the output voltage , that is measured by AC voltmeter ? Should it be the same as calculated by the formula that you provided i.e. Vr = Rmeas * Is .......... Am i right ?
what range of AC supply can be provided to test all these three types & of what range of frequency ?
Circuit A: We measure current through coil by voltage across Rmeas.
Circuit B: Act as transformer
Circuit C: Changes in magnet field generate measured voltage
But use allways additional series resistor so that current can not
increase too high. ( for sensors maybe 10mA is enough )
Frequency in range 50Hz... 10kHz
