How to test all inputs and outputs of the S7-200 PLC ?
DrWhoF
Advanced Member level 1
Can someone advice how to test all inputs and outputs of the S7-200 PLC (222CPU).
Maybe a simple program, as I am not familiar with this stuff and have to test it.
:D
s7-200 serial port pin
Write and download a program that sets output when input is pulled-up to a “1”.
It may look like this (STL option in Step7-Mico/Win):
Input: I0.0
Outputs: Q0.0, Q0.2 and Q0.4
Network 1
LD I0.0
= Q0.0
= Q0.2
= Q0.4
You can do the same for input I0.1 and outputs Q0.1, Q0.3 and Q0.5:
Network 2
LD I0.1
= Q0.1
= Q0.3
= Q0.5
and you can do the same for all other inputs ..
Rgds,
IanP
    DrWhoF
forum s7200
OK.
I made a cable connected as per this discription:
but there is no communication between PC and PLC.
Any (prompt) advice is highly appreciated :!:
s7 200 rs485
What serial port has your PC?
You need the RS-485 to connect to S7-200 and the connection is gnd on pin 5, line A(Tx/Rx+) on 8, and line B(Tx/Rx-) on 3 ..
Rgds,
IanP
    DrWhoF
s7 ppi test
Hello!
I put in one of my posts some schematics how to build a cable for S7-200.The post is Siemens useful cables.
Another great resource(different from Siemens official sitewww.simatic.com) for programming S7 PLC family is www.plc.net.ru
Best regards!
Venix
    DrWhoF
test port s7-200
My mistake, I tried to connect through rs232.
Thanks for the info on 232-485 connection.
I'm going to try it. :D
rs 485 connection and s7200
I hope you’ve managed to establish connection with the PLC ..
After all they are pretty robust, so even if you try the RS232 signals on the RS485 pins it should survive ..
Rgds,
IanP
    DrWhoF
Re: S7-200 test
Dear Inap.
i made the rs232 to rs485 converter to s7-200..it semes to be worked ok..
but now i test this converter with commander sk drive converter,and there is no communication please advice to solve this problem...
Best Regards.
MedTronic
